Do anyone know what kind of bulb can fit in this holder?
Discussion in 'Electricians' Talk' started by Alexander123, Nov 5, 2018.
Tags:
  1. Alexander123
    Alexander123 New Member
    Do anyone know what kind of bulb can fit in this holder? And where can I buy this kind of bulb?
  2. retiredsparks
    Never seen one before...must be some cheap chinese import.
    I guess there are no DIY shops like BnQ, wickes, Wilko etc. within 200 miles of you.
    :rolleyes:
    RS
    WillyEckerslike likes this.
  3. Alexander123
    For one thing, it's not cheap.:confused:
    for another, I'm in central london....
  4. Bazza
    Bazza Well-Known Member
    KlausK likes this.
  5. DIYDave.
    DIYDave. Well-Known Member
    Blimey, you may be in central London but where exactly ...... living in a cave for the last 50 years ??
    Probably the most common lamp holder style, but fair enough, if you don’t know, you don’t know
    It’s a ‘bayonet’ fitting
    Come in 2 sizes - small and er.... standard
    Also abbreviated to;
    SBC - small bayonet cap
    BC - bayonet cap
    Literally everywhere that sells lamps will stock a range of lamps using this fitting
    Loads of LED equivalents available as gradually the standard filament and the later halogen lamps are being phased out
    So uv got local electrical shops, supermarkets, BQ, Homebase, Wickes, lighting shops, Internet
    Out of interest, what kinda lighting you been running in ur cave ??
    :) Good Luck ....You can do this :)
  6. retiredsparks
    ...and another thing...you must be as thick as four short planks if you do not know...and /or to waste times trolling.
    The best i can wish you is ..leprosy.(Spike Milligan):)# RS
  7. Alexander123
    The thing that bothers me is the pillar in the cap. Don't konw what's that used for.
    Anyway, thanks!
  8. Bob Rathbone
    B22 is the size, probably the most recognised of all electrical outlets. Now I suggest that with your lack of experience here, you get an electrician in to do the job.
  9. Pollowick
    Pollowick Well-Known Member
    Pillar ... what pillar? All I can see is one of the contacts.
  10. Pollowick
    I'm close to central London - easy enough for me to call in and see the OP. £200 should cover my time.
    retiredsparks likes this.
  11. Isitreally
    Isitreally Well-Known Member
    Daffodil or Tulip, either will look nice in bloom.
  12. PhilSo
    PhilSo Active Member
    Maybe that's the problem.
    Only one spring loaded contact.
    Perhaps that's why it doesn't work.
    Just a thought :rolleyes:
    PhilSo
  13. PhilSo
    Are there two brass prongs in the lampholder?
    PhilSo
  14. retiredsparks
    Lets hope this OP does not drive or breed !
    My 5 year old grandson would know how find the name of the fitting and where to buy a bulb for this unit... within 5 mins of being asked.
    RS
  15. furious_customer
    furious_customer Active Member
    To be fair, I was looking for a full size bayonet cap fitting the other day in Tesco and struggled to find them - they are definetely being eclipsed by ES and SES type fittings - probably because Ikea don't seem to sell any BC lamps or light fittings.
    I had a quick look on the "bulbs" section of Ikea to see if they sold any BC bulbs and they don't - but they do have BC to ES converters.
    https://www.ikea.com/gb/en/products...oppla-b15-to-e14-bulb-converter-art-70296574/
  16. Pollowick
  17. furious_customer
    Wouldn't they have just wired the pad at the bottom of the BC connector to the centre pin?
  18. Allsorts
    Allsorts Well-Known Member
    Alexander, assuming there are two prongs still in that holder and one hasn't broken off, I recommend these Philips WarmGlow lamps: https://www.ebay.co.uk/itm/2-x-Phil...d:g:jR4AAOSwXzNaXwZq:rk:2:pf:1&frcectupt=true
    If you decide to add a dimmer, they should still work. They are fab. There will be slightly cheaper non-dimming LED lamps out there if that's all you want, but frankly the Philips are so good I'd be reluctant to go past them - a very natural traditional (filament/halogen) colour, and they 'warm' as you dim them just like the 'real' thing.
  19. Pollowick
    A bayonet has 2 pins - one live and one neutral. So, yes they wire one of them, but which one? There is no way to guarantee live to centre using that adapter type and 50% of the time it will be wrong.
    furious_customer likes this.
  20. Comlec
    Comlec Well-Known Member
    This is not a requirement for fittings that comply with BS EN 60238
