M
Mr. Handyandy
Guest
See above.
If - IF a bugle head fits the hole better and flush, or IF the d-countersink fits the hole and flush, WHY would it be bad practice to use them?
Mr. HandyAndy - Really
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
See above.
Who mentioned bad practice apart from you, it isn't best practice but that is a different thing.If - IF a bugle head fits the hole better and flush, or IF the d-countersink fits the hole and flush, WHY would it be bad practice to use them?
You realy have no idea what a huge manopausal idiot you have become.
No I didn't, this is all inside your head, how you interpret other peoples words is up to you but all your solutions other than drilling a bigger hole, which would involve re grinding the drill to another angle, were wrong.I think you are talking about yourself.
It is in black and white.
I suggested something. You said my advice was wrong. Then you admit that it is not.
Loser.
When's the wedding you two
You are changing my words to suit your non-answers.No.
Using a different countersink screw may work(fit the hole better).
That is CORRECT. You have admitted that while NOT bad practice, it isn't wrong.
What's your problem?
And this shows how thick you are. Where did I say drill a new sized countersunk hole? With a different angle?
I didn't.
Drill the hole in the bottom of the countersink bigger to allow the bottom of the screw countersink to go down lower.
I never said anything about changing countersink hole angles or regrinding drill-bits.
You are making it up to get out of the 'own' hole you have dug for yourself.
Now there's a good chap.
Drop it, before you get so deep you can't get out(may be too late).
Twit. Astounding naivety.
What you should do is use the correct screws to match the hinges, all your advice was to use the wrong screws and bodge it.
People are coming on this site to get professional advice not some handy man lash up delivered by an increasingly hysterical hormonal harridan.
Hardware is countersunk for screw 2
Give it a sharp tap with a hammerAnyway, the shortest answer is, if it doesn't fit
