M
Mr. Handyandy
Guest
Jealous.![]()
Jealous coz you frightened all your kids away. remember, I read between the lines!
Mr. HandyAndy - Really
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Jealous.![]()
Well there is one upstairs and the other one is at Uni studying Bio-medical science.
Do you actually read and understand what is being posted?Yah, a carpenter that doesn't have the sense to use a different screw if the screws he has don't fit.
Some knowledge that!
Is that the sound of a barrel being scraped, going to University to be educated is quite commom and stops you from ending up as a second rate handyman and a teenager being in his bedroom on a computer is also pretty common.One moved out and one hides upstairs! Frightening.
As long as you use annular ring nails.I use nails...just bend the head over. Nothing like a satisfying slam to shut a door!![]()
Ring shank nails would work.I use nails...just bend the head over. Nothing like a satisfying slam to shut a door!![]()
As long as you use annular ring nails.![]()
Your advice was to use the wrong type of screw.
Shut up you moron, why would you buy the wrong type of screw on the off chance it may work when you could buy the correct screw which will fit, sorry I know the answer to this, it's when you're Handshandy and as thick as mince.The wrong type of screw but which fitted flush as desired.
Lost heads.Oval are best![]()
