Hi, Sorry for the noddy question but i cant find the answer here b already - Im repainting a white wood door and architrave, the existing paint is in good condition, just a bit yellow. I think its satin wood paint. Do i need to bother priming this or can i just lightly sand down and repaint in Satin white? Thanks
Waterbased or oil based paint. Some waterbased you do while others you don't. What paint you using? If painting on old yellow oil based paint I always prime with waterbased primer regardless
Only need to prime bare wood, so basically no However, if after sanding down, you do hit bare wood (sometimes happens on the edges when you sand), then just ‘spot prime’ these sections As the paintwork is yellowed, this suggests it’s solvent based paint, prone to yellowing over time What paint are you using here - solvent or water based ? After a light sanding and dusting, give the woodwork a good wash down with hot water and sugar soap, followed by a wipe down with clean water and rag Can be traces of household polishes, grease from hands, etc on woodwork which can play havoc with new paint If using water based paint, I would be tempted to Undercoat after prep and any priming
Primers seal a new surface your door has been previously painted so a primer is not required, at best an undercoat would be advised to provide a good key for the top coat, however most Satin paints are self undercoating and would only require the existing surface to be lightly sanded and cleaned prior to applying two coats of paint to re-finish.
