Do I need to remove all plasterboard?
I’m renovating my bathroom and installing tile backer board on several walls where tiles were removed. There are two other adjoining walls with moisture resistant plasterboard. Should I remove the plasterboard from these walls as well, or can I leave it and tile over it?
If it’s not in a shower area but is just a splashback over a sink, or where tiles are just decorative, then moisture resistant plasterboard is fine.
A friend of mine is having his bathroom done and the builders are using moisture resistant PB....i told him a proper shower board like Elements would be better. Builders disagree / cant be bothered!!!!!
I agree with you that cement based boards are better and it’s what I would use in a shower. However, MR plaster board is in most instances sufficient and if I were your mate I wouldn’t worry. There are plenty of 1980s bathrooms with showers over baths tiled on ordinary PB with no problems after 40 years’ service.
Agree with Kools: MR still gets mushy when it gets wet, perhaps a bit slower than the normal stuff is all (how do I know?) Next time I'll use cement board fo sure.
Just to be clear, I agree that where the grout or seals fail, MR plasterboard can be damaged, which is why I would use cement board. However, I also think your friend doesn’t need to be overly worried - grout is pretty reliable these days and silicone seals can be redone if they are showing signs of failing.
Back
Top
