Do Newly Plastered Walls Crack and Should They be Lined With Paper
Discussion in 'Painters' Talk' started by u0362565, Jul 11, 2019.
  1. u0362565
    u0362565 New Member
    Hi all,
    We're getting our house plastered and and we just want a paint finish on it. However, some decorators and plasterers have said cracks may start to appear in the plaster even weeks after its done. Is it a good idea to leave the plaster bare and paint or would most people at least use lining paper-this seems expensive though. If it does crack in places is it easy for anyone to repair? Place was built in 1860's so quite old.
    Thanks for the advice
  2. sospan
    sospan Well-Known Member
    By plastered do you mean from bare brick / stone or skim over the top of what is there already ?
    Old house move about quite a bit especially if you have trees nearby and we go through dry spells followed b wet. Hence they are quite prone to cracking in lots of places
    If it is from the bare stonework I would leave it for a while to see how it settles and to see if there are any signs of damp.
    If you are skimming then it should be ok to paint once the plaster has achieved an even colour
    Fine cracks and blemishes can be fixed with a good quality filler and then sanding.
  3. u0362565
    u0362565 New Member
    Its mostly a skim over existing plaster, in places the old plaster is coming away so assume will be knocked off and redone. Sounds as if we'd be ok just with a paint finish then if we're willing to fill cracks here and there as they develop.
  4. sospan
    Yes, you shouldn't have too many, just a few hairline ones which will only show on light colour finishes.
  5. Astramax
    Astramax Well-Known Member
    Save your money and make repairs to plaster where required and line walls with WallRock Fibreliner.
  6. gac1967
    gac1967 Member
    Im with Astramax on this repair all holes and cracks and line all the walls with Wallrock Fibreliner - Fantastic product
    Astramax likes this.
  7. Astramax
    Makes a lot of sense, a lot quicker and far less mess and would work out less expense!;)
  8. u0362565
    u0362565 New Member
    Too late plasterer is booked and coming so skim is happening. Doesn't mean we couldn't line with this Wallrock Fibreliner after that but the whole idea was to not have to mess about with wallpaper and just paint it! Fail.
