Hi I am getting my bathroom re-fitted and i have a quote to put in 4 led spot light at £261.38 cost only. My question is do you think they will be bright enough? Do you think its a waste of money? Do you think it a nice touch to have something different?
4 for £261.38 cost only :O Stick in some shower proof GU10'S with led lamps £15 max each..............However you will still need your torch to find the taps, Well not that bad. These Led lamps give off a blue-ish light that can seem cold. I tried a few at home to see.If you fit more, then this may do
You could try these: http://www.qvsdirect.com/7W-GU10-Compact-Fluorescent-Lamp-p-21559.html But as Slipshod said, these give off a very white light which may 'feel' cold. Brighter than LEDs though.
I fitted 3 X 40mm ones above the bathroom mirror and still needed to put the overhead lights on to do my makeup! Depends on the size of the fittings to the output but S&Ss suggestion of GUs is best, at least you can replace the bulb if it doesnt work out and about third of the price.
I fitted 3 X 40mm ones above the bathroom mirror and still needed to put the overhead lights on to do my makeup! Maybe thats because you have been dead a hundred years
But seriously: No - they are crap. Yes - they are crap. Only if you think different but crap is nice.
