does a new hob fitting need a certificate
Discussion in 'Electricians' Talk' started by orbital, Dec 19, 2006.
  1. NikT
    NikT New Member
    Now I know where Tolkien got his ideas from for the
    triology from all these posts
    This ones the base for the Hob it and Lord of the
    Rings, now got to work out the how the Two Towers
    come into this
    The NZ reference again..:^O
  2. Ripped Off
    Ripped Off New Member
    the
    come into this
    Ah ha The Two Towers Mr & Mrs N
  3. NikT
    NikT New Member
    :)...:^O
  4. Ripped Off
    Yep starting to get into the xmas spirit, now wheres the Southern Comfort.
    Got to switch off from work somehow ~ got VAT to do B4 the 31st.
  5. NikT
    NikT New Member
    VAT man on holiday isn't he??
  6. Ripped Off
    That Ba** is only one above the tax vulture. Not in on time bet on the 2nd Ive a penalty notice and please donate £100 to our next xmas bash on my door mat
  7. NikT
    NikT New Member
    One thing that has always bothered me.
    Why do you get a longer sentence for tax evasion than murder?
  8. Stoday
    Stoday New Member
    Part P document (have a copy)
    <u>Page 8 Section O</u>
    0.8 Notification of work
    Item b i,
    When the non notifiable work described in table 1 is
    to be undertaken professionally, a way of showing
    compliance would be to follow BS7671:2001 and to
    issue to the person a minor electrical installtion
    works certificate.
    Ant
    You are wrong Ant.
    Your copy of part P is out of date. It was revised in April 2006 and the revised edition excludes the paragraph you quote.
    That means that the arguments in half the following ten pages are invalid too.
  9. 2 wheeled ant
    2 wheeled ant New Member
    Stoday acording to some im wrong all the time anyway so just keeping to form
    At least i try to understand things instead of blindly following like sheep
    Ant
  10. Clark Kent
    Clark Kent New Member
    With so much documentation/regulations etc now applied to electrical installation, it's no wonder confusion happens..
    If you PAT test a electrical item, you issue a sticker and record the results.
    So whats the difference when interfacing to fixed wiring, you perform some tests, they should be documented..
    Not just for compliance to the Regs or whatever, but to confirm you have correctly connected and tested the fitting concerned and it functions.
    You wouldn't buy something from the shops without a reciept/guarentee would we?
  11. Real Spark
    Real Spark New Member
    This has turned into a HOB for NOBS
    No cert required
    Still no no no no
    RS
  12. Clark Kent
    No cert required
    Still no no no no
    RS
    Whatever...............
    Merry Christmas all...:)
  13. 2 wheeled ant
    I wonder if the ones who dont want to give a cert for changing a hob either,
    Cant fill in a form
    Changed so many items without giving a cert, so dont want any come backs on them
    Dont do any tests at all
    Check MCB/cable size
    Merry Xmas to ALL
    Ant
  14. NikT
    NikT New Member
    And a very merry xmas and happy new year to you all!
    Don't get too drunk. ;)
  15. sparky Si-Fi
    sparky Si-Fi Screwfix Select
    Talk about creating extra work for yourself.
    Cert for a hob
    For crist sake get a life !
  16. Clark Kent
  17. NikT
    NikT New Member
    My answer is still no you don't need one.
    However, i can see the other lads point of view to cover their backs and have a paper trail.:_|
    In this day and age of litigation, it is very sad.
  18. Triplock
    Triplock New Member
    First post in about 6 months, but this thread warrants a response. When installing the hob,you will make an assessment of the existing sub-circuit, with complimentary testing as required. You clearly wouldn't install the accessory if you intuitively felt there was something amiss. Also, as the fixed wiring ends at the point of connection, strictly speaking there is no requirement to issue a MWC.
    A lot of electricians on here seem to be on some sort of stubborn electrical safety crusade, with an over-zealous interpretation of the regulations. At the end of the day lads and lasses, our trade isn't rocket science. There really isn't any need to over analyse every application.
    Therefore, why issue a MWC for installing a hob. It's a waste of time.
    Merry Xmas.
    Triplock
  19. sparky Si-Fi
    ..............that link was ace!!
    Merry Xmas everyone have a good one
  20. Real Spark
    <u>OK for the sake of peace I give in here is you MWC</u>
    MINOR ELECTRICAL INSTALLATION WORKS CERTIFICATE
    (REQUIREMENT FOR ELECTRICAL INSTALLATIONS &#150; BS 7671 [IEE WIRING REGULATIONS])
    To be used only for minor electrical work which does not include the provision of a new circuit
    PART 1 : Description of minor works
    1. Description of the minor works:
    Replace electric hob
    2. Location / address
    Mr Nob
    11 Hob Lane
    Hobleton
    3. Date minor works completed: 24 Dec 2006
    3. Details of departures, if any from BS 767:1 None
    PART 2 : Installation Details
    1. System earthing arrangement TN-C-S 1 TN-S 0 TT 0
    4. Method of protecting against indirect contact: EEBADS5.
    3. Protective device for the modified circuit Type&#133;B&#133;&#133;&#133;&#133;&#133;.. Rating &#133;&#133;&#133;&#133;20&#133; A
    Comments on existing installation, including adequacy of earthing and bonding arrangements: (see Regulation 130-07)
    None
    PART 3 : Essential Tests
    Earth continuity satisfactory 1
    Insulation resistance
    Phase/neutral &#133;&#133;&#133;&#133;&#133;>200&#133;&#133;&#133;&#133;&#133;M ?
    Phase/earth &#133;&#133;&#133;&#133;&#133;&#133;>200&#133;&#133;&#133;&#133;M ?
    Neutral/earth &#133;&#133;&#133;&#133;&#133;&#133;>200&#133;&#133;&#133;&#133;M ?
    Earth fault loop impedance &#133;&#133;&#133;&#133;&#133;&#133;0:55&#133;&#133;&#133;&#133; ?
    Polarity satisfactory 1
    RCD operation (if applicable). Rated residual operating current I?n 30 MA and operating time of N/A Ms (at I?n)
    PART 4 : Declaration
    I/We CERTIFY that the said works do not impair the safety of the existing installation, that the said works have been designed, constructed, inspected and tested in accordance with BS7671 2001.(IEE Wiring Regulations), amended to 2004 and that the said works , to the best of my knowledge and belief, at the time of my / our inspection, complied with BS 7671 except as detailed in part 1.
    For and behalf of: Real Spark
    Address:
    Signature
    Position: Approved Electrician
    Date: 24 Dec 2006
