Does fitting a separate CU preclude testing existing circuits
Discussion in 'Electricians' Talk' started by Lokkars Daisy, Oct 25, 2012.
  1. Lokkars Daisy
    Lokkars Daisy New Member
    In the course of my much varied enterprise I happened on this opinion
    Connecting a new circuit into an existing consumer unit requires checking of existing circuits.
    Breaking into the meter tails fitting a Henley box and a separate consumer unit reduces the responsibility for checking and signing off the existing wiring
    Is there any truth in the above, and if so, why?
  2. seneca
    seneca Screwfix Select
    Adding a new circuit to an existing c/u only requires testing of the new circuit and earthing and bonding etc. Lokks, no requirement to test all the existing circuits.
  3. Lokkars Daisy
    That's true seneca, so if you were to fit a separate consumer unit for a for an aditional circuit would there be any less testing involved, I'm sure not, but just running this up the flagpole . The above comments re testing , are from a manufacturers advice with reference to connecting a solar panel to an installation
  4. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Surely you'll be altering the characteristics of the supply(1 supply SHARED between 2 distributions), which may affect all other parts of the installation, so they should all be tested for ok?
    No ?
    Mr. HandyAndy - Really
  5. seneca
    I can't see there would be any less testing required Lokks, you'd still have to test the new circuit and earthing,
  6. Lectrician
    Lectrician Screwfix Select
    Yep, only test your new circuit whether it be from a new small CU or the original.  If you had to replace the old CU to make room for spare ways, you would have to test all.
  7. seneca
    That's correct Handy, as you said NO.
  8. unphased
    unphased Screwfix Select
    I agree with sen. :)
  9. wally
    wally Screwfix Select
    I agree with sen & Lec
  10. Lokkars Daisy
    I agree with sen, lec & un
    the manufacturer has had a bum steer
  11. J.P.
    J.P. New Member
    Irs like when you build an extension. Whip in a DB specifically for said, and forget messing with the existing DB.
  12. Lokkars Daisy
    Yeah JP , forget about messing about with existing stuff but constaints are still the same
