Door noise
Discussion in 'Carpenters' Talk' started by Ethanpeng, Apr 17, 2019.
  1. Ethanpeng
    Ethanpeng Member
    I am not sure I post this in the right place if not let me know please. My bedroom door make noise by scratching the carpet every time I open or close it . Any solutions? Thanks
  2. Pollowick
    Pollowick Well-Known Member
    Remove door, and trim off the necessary amout to ensure it misses the carpet. Either plane, saw or router.
  3. DIYDave.
    DIYDave. Well-Known Member
    Has this always been the case or has it started since you’ve had new carpets fitted ?
    Also check that hinges aren’t loose in frame/door which can cause the door to drop and catch on carpet
    Few more details required
  4. sparky steve
    sparky steve Member
  5. Severntrent
    Severntrent Active Member
    Might be able to sort by packing out the bottom hinge slightly but that depends on how well or badly the door has been fitted.
  6. ginger tuffs
    ginger tuffs Active Member
    it sound to me if its a hollow door the bottom has been cut but the bottom has not been replace causing the sound
