If I wanted to fit a new door open close actuator something like http://bit.ly/2E3naml basically to use on a car alarm separate from factory fitted ones, Would I need to run power to the actuator or would one pin be ground and the other from the alarm output for negative door trigger (-) or is it a bit more involved than that?
