Doors
Discussion in 'Carpenters' Talk' started by mrppp, Mar 11, 2018.
  1. mrppp
    mrppp Member
    Are the oak veneer doors sold at Wickes the same as those sold at Howdens? Look the same only cheaper at Wickes.
  2. chippie244
    chippie244 Super Member
    I can't say for definite but there are some manufacturers ie Premdoor who sell the same product to lots of retailers.
  3. mrppp
    mrppp Member
    Only thing i noticed is on Wickes it says "These doors are not suitable for treatment with any type of oil, wax or polish" But I know previous Howdens doors i have always used danish oil no problem on.
  4. fillyboy
    fillyboy Screwfix Select
    It said no oil on some howdens doors I fitted last week. I've fitted howdens and wickes recently and could see no difference. I had to haggle quite hard to get a reasonable price from howdens, wickes had a buy one get one free offer, but for some strange reason that didn't apply to the glazed doors (I needed 5 plain and 5 glazed) so they worked out similar price, I went with howdens because I can rely on them to deliver without damaging them.
  5. mrppp
    mrppp Member
  6. fillyboy
    Interesting, on that howdens link it says ok to finish with osmo oil, but it definitely said no oil on the instructions. Also, howdens, maximum trim per side 5mm,
    wickes maximum trim 20mm.
  7. fillyboy
    If you don't need the glazed version, I'd go for the wickes ones, far cheaper. Where I fitted the wickes ones the owners did oil them with no problems appearing.
  8. Jord86
    Jord86 Screwfix Select
    The small differences between them is usually the shade of oak being slightly different, and different thickness lippings edged around the door. If your frames are poor I'd opt for the doors with the deepest lippings, as you'll need to plane lumps off to get the doors to fit.
  9. AlvyChippy
    AlvyChippy Active Member
  10. sospan
    sospan Screwfix Select
    Veneered doors are one of my pet hates. Some have incredibly thin veneer and the slightest scratch or ding can ruin the door. Some doors aren't covered in a one piece of veneer and some times you have glue lines on the surface which only show once the door is finished.
    If you are going to buy veneered doors try and buy the finish from the same supplier and preferably one they recommend - just in case you do have a problem, they can't say it was a product bought elsewhere.
  11. Jord86
    My heart sinks when I'm asked to fit them to existing frames, time they can take is incredible, won't do them for less than £60 each now. Weigh a Damn tonne too, gotta be so careful in taking it up and down the stairs.
  12. mrppp
    mrppp Member
    So other than solid oak what other alternative for a "decent" door?
  13. sospan
    Can understand a little why they are made for interior use - but for front and back doors, no way. Kids, pets scratching the door, carrying things in and out.
  14. mrppp
    mrppp Member
    The last I had from Howdens I oiled all of them without issue. So strange Wickes and Travis P doors say no oil
  15. mrppp
    mrppp Member
    Oh yes, this is internal doors not for anything exterior, i would not even consider them for that
  16. sospan
    What is the finish you want ? painted or wood
  17. mrppp
    mrppp Member
  18. fillyboy
    I suspect the oil thing isn't an issue and the manufacturers are covering their ***** in respect of the oil causing delamination. Trouble is, if you use oil and the veneer does peel, no warranty. But that said, I've never heard of a problem in this respect.
  19. goldenboy
    goldenboy Super Member
    Just done 14 oak veneer doors. They just take time and lots of TLC when hanging and I adjust the price accordingly. For me the best finish is 2 coats of Ronseal Diamond Hard varnish. Put an extra coat on the inside of cloakrooms and bathrooms though.
  20. fillyboy
    Out of curiosity, how many would you expect to hang a day, I know the frames can vary and one door can take twice as long as the previous one.
