Dot and dab - newbie advice please
Discussion in 'Builders' Talk' started by diymostthings, Aug 11, 2018.
  1. diymostthings
    diymostthings Well-Known Member
    Will soon be having my first go at dot and dab dry lining. To make it easy for you experts, my 4 questions have a simple Y/N answer!
    Q1: Should I/could I use quick setting cement in the mortar?
    Q2: Should I use cement plasticiser (e.g. fairy liquid)?
    Q3: Substrate is fairly uneven but sound plastered masonry (bit of paint here and there). Should I use latex PVA in the mortar mix and/or on the plastered surface (where the blobs will be, until tacky).
    Q4: Do I need to leave a small gap between the floor and the bottom edge of each board?
    Thanks in advance for any Yes/No answers (or a few more words if you have the time!)
    diymostthings
  2. blarblarblarblar
    blarblarblarblar Active Member
    Q1, Dot & DAB, cement in the mortar?
    Q2, No cement in board adhesive?
    Q3, Still confused.
    Q4, Yes.
    Hope it helps, been D&Bing all day....
  3. Magicspark
    Magicspark Active Member
  4. fillyboy
    fillyboy Well-Known Member
    1. Eh?
    2. Eh?
    3. Eh?
    4. Yes
    You don't use mortar for dry lining, use board adhesive, mix as directed, 1 bag should do 2 full size boards. Leave the fairy liquid in the kitchen.
    blarblarblarblar likes this.
  5. stevie22
    stevie22 Active Member
    You use drywall adhesive not cement mortar. Plenty of how to vids on you tube.
    make sure you have a good straight length of 4x2 to gently beat it into line
  6. diymostthings
    Ah - i fell at the first hurdle - I thought the "adhesive" was mortar!
  7. diymostthings
  8. diymostthings
    OK thank you!
  9. blarblarblarblar
    No mate, nothing like it. More like filler tbh. Sticks to everything and goes rock hard once dry, mix it by the bucket load. I tend to use 1 bag on roughly 1 and half sheets, don’t quite manage two sheets as I like to make sure it’s pretty solid.
    Good luck with.
  10. Magicspark
    How many boards you got to stick?
  11. fillyboy
    I've never tried the foam, how do peeps find it to use compared to normal adhesive?, I would imagine it needs a gentler approach.
  12. sospan
    sospan Well-Known Member
    As well as big piece of timber to persuade it into place, you need a long spirit level to make sure the board is plumb (vertical)
    You will also find it quite difficult to mix in a bucket with a stick - you will need a strong drill and a paddle mixer attachment
  13. diymostthings
    Thanks - I think I need it!
  14. diymostthings
    well its not plasterboard as such - its "Jackoboard" with waterproof faces and foam interior. its for a shower room with three external walls (so I needed the insulation core). But the instructions say "dot and dab" in place. Which is why I asked the questions. Thanks for your reply. Much appreciated.
  15. diymostthings
    I have got a paddle mixer for my Dewalt drill and have used this successfully to mix up "multi". Thanks for the tips.
  16. sospan
    Jackoboard normally requires a rapid setting single part flexible (SPF) cement tile adhesive, which again is different from dot and dab adhesive. I would also add fix into the wall with good quality wall plugs and screws.
  17. diymostthings
    Thanks for that- yes I have some of the special plastic "washers" for screw fixing and will now look into that SPF adhesive.
  18. chippie244
    chippie244 Well-Known Member
    Pink foam is excellent.
  19. diymostthings
    Do you mean the polyurethane foam which expands on application? I can't see how I could get the boards flat and in line if the adhesive is expanding...?
    Thanks Chippie
  20. Magicspark
    He means the same thing I linked to earlier.
