Hi, I'm about to start putting a stud wall up in what was an archway to accomodate a set of double doors.
The doors I have are 1981mm(h) 1524mm(w) 35mm(D).
I have a 10mm Pairmaker.
The door lining is 30mm.
So just want to check how big I should make the gap in the stud wall.
I'm told that 3mm clearance on each edge is what I need so..
Width:
1524 Both doors plus
10 Pairmaker plus
60 Door lining plus
9mm Clearance on both sides and between the two doors.
1603mm total width.
Height:
1981 Door height plus
30 Door Lining
6 Clearance
Plus floor covering yet to be decided.
Are my calculations correct or do I need to add an extra 3mm on the width (2x3mm on the meeting edges or the doors)?
Or am I way off
Width:
10 Pairmaker plus
60 Door lining plus
1603mm total width.
Height:
30 Door Lining
6 Clearance
Or am I way off
