Double washer OK?
Discussion in 'Plumbers' Talk' started by Ammar Al-Taweel, Jul 16, 2020.
  1. Ammar Al-Taweel
    Ammar Al-Taweel New Member
    Hi all,
    I have a shower mixer back plate on the wall and I am trying to fit a new shower mixer to it. The problem is that the new shower connectors thread is too deep for the plate's thread, so I can't tighten it enough to prevent a leak.
    Is it a good idea to put an extra washer in the mixer's valve to give me more space or is that a bad idea?
    Thanks.
  2. nigel willson
    nigel willson Screwfix Select
    If it works, it works
  3. terrymac
    terrymac Screwfix Select
    Post pics of the fittings.
  4. Ammar Al-Taweel
  5. AnotherTopJob
    AnotherTopJob Screwfix Select
    As long as there is enough thread it should be Ok but it might retightening occasionally.
    A thicker washer rather than 2 together might be a better solution.
    Ammar Al-Taweel likes this.
  6. Ammar Al-Taweel
