I wish to extend a 60mm dia guttering downpipe away from a soakaway. I cannot find 60mm OD downpipe. It's too much to replace all of the system. Is there a adaptor to 68mm / solution ? Thanks
Should be manufacturers details on the pipe. Or on the guttering/brackets. Go look.. Every part has something marking it Quick Google https://uk.rs-online.com/web/p/pvc-pipes-plastic-pipes/2123953/
Take a look online at ‘Drainage Pipe Coupling’ Huge range of types and sizes available, basically a rubber sleeve that goes over both pipe ends and secured with 2 stainless steel (should be) jubilee clips As made of soft but tough rubber, each size coupling will deal with a range of pipe sizes as will be stated As you’ve only got a difference of 8mm, an equal coupling will do the job They may be more bulky than a plastic type adaptor but just depends how important this aspect is and what else is available. Will do the job though for sure - it’s what they’re designed for eBay, Amazon, or Drainage Superstore is a company I’ve used before
The rubber couplings look a bodge and are a bodge, if doing a job, do it properly with the proper materials, not a make do bodge with what looks like a radiator hose for cars, vans and lorrys.
Cmon, get over such ‘bodges’, s hit happens, rubber couplings get used, they will do the job at hand without doubt and must be manufactured and sold by the millions Is everyone a cowboy bodger that uses such an accessory ?? Same as every fast fit back box used, every sheet of plasterboard that’s ever dabbed to a wall and every sheet of chipboard flooring used that’s then covered with underlay and carpet and thus never seen again for the next 20 years Several ways to do any job and often these various methods are all acceptable - just giving some options to consider and free choice I’ve no idea if a solid adaptor exists that will join 60-68mm pipe ? Have you Deleted member 11267 ? If such an item does exist, then excellent, the OP then has a choice of 2 methods to consider (maybe other solutions also available) ? Ok, the coupler may not be the most handsome thing to look at but, is it on show and highly visible ? We just don’t know do we At this stage it’s just guess work, it may not even bother the OP - he may be a fan and collector of rubber items There may not be an alternative - I don’t know, I’m not going to do the leg work for the OP - perhaps you care to add some value to the post in the meantime
He says he is going to a soakaway which should be a minimum of 5 metres from the building. Rainwater pipe will then be the wrong type of pipe to run anyway.
