Downlight replacement issues
Discussion in 'Electricians' Talk' started by Netta, May 11, 2017.
  1. Netta
    Netta New Member
    Hi everyone- hope someone can help.
    I am trying to replace some faulty downlights that have warped surrounds and fall out. They are held in place by 3 clips but nobody seems to sell this type of fitting. I bought replacement downlights but they are installed by 2 Spring clips and is too wide to fit into ceiling as the downlights I have came down but there is still a fixture attached to the ceiling which I can't seem to get out.
    Please see attached photo of the ceiling fitting which I can't remove.
    Can anyone suggest the best way of replacing? Is there a trick to getting the ceiling fitting out? Or can I buy a surround that will clip into what I already have in place? Have also upgraded all globes to LED from Halogen as I think the heat probably caused the warping as well.
    Thanks
  2. Netta
    Netta New Member
    Here is the fixture that comes out of hole... these are what I need to replace ... note the 3 clips that are supposed to hold it in place in ceiling.
  3. Lectrician
    Lectrician Screwfix Select
    You would need to replace the whole lot - The bit in the ceiling will pull down, and has two spring clips on it as per the fitting you have bought.
