downlights that dont give off heat
Discussion in 'Electricians' Talk' started by 40w bulb, Feb 7, 2008.
  1. 40w bulb
    40w bulb New Member
    are there any kind of downlights that dont give off heat on the market? Or ones that are less of a fire risk?
  2. JP.
    JP. Screwfix Select
    LED downlights..not au fait with the forward heat emissions of LED downlights but suspect a negligible heat throw..ie unmeasurable 20mm onwards from surface.
    Thus to all intents and purposes they do not give off any appreciable heat..however they are **** in most lighting situations.not all however.
  3. 40w bulb
    40w bulb New Member
    thanks for that JP, would you say they are s*, f* or w* in a living room?
  4. JP.
    JP. Screwfix Select
    It depends on what you want 40w..best to get a general opinion from the sparks on the forum as it would be wrong of me to just to say they are ***** full stop etc as they may suit you perfectly adequately..
    Will say one thing though..they are good/excellent for niche lighting.
  5. Luxeon LED are a top product.
    Fitted 30 of these badboys in a shop last week and they look the nuts.
    3w and about the quivalent of a 40w normal halogen.
    Pricey mind you, at a tenner plus vat.
    I shall be fitting em in my landing and hallway during the spring.
  6. JP.
    JP. Screwfix Select
  7. adchesney
    adchesney New Member
    How about installing low energy bulbs. 11W = 60W and give off little heat.
    ANDREW
  8. Tootyfruity
    Tootyfruity New Member
    I'd say 1 led, in a living room, is much better than a feckin 40w bulb.
  9. Jimbo
    Jimbo Screwfix Select
    one LED, nice ;)
  10. The Megaman 11w GU10 give off more light than a standard GU10 50W and only run warm. You can now get 'dimmerable' ones, and pink'ish or blue'ish tints.
  11. enell
    enell New Member
    And wont fit in the standard flameproof spot.
  12. And wont fit in the standard flameproof spot.
    Flameproof spots are availible for these lamps. Quite usefull for your part L requirments as normal GU10's wont fit.
