Steve200000023
New Member
Hello there.
We purchased our house 2 years ago that was identified to have areas of damp, and I am now looking to see what I can do to rectify the situation.
On inspection, the house has solid floors, but the DPC is 2 brick courses below the internal finished floor level!? With the top of the air bricks level with the internal floor, I have read that people can install concrete floors to replace timber joist!? which would explain why the DPC level is correct for a timber joist floor and not for the replacement floor.
Q1. If I was to buy a DPC injection kit, would I go the 2 courses higher than original DPC so that it would now be level with the current solid floor.
Q2. If I lay a new patio with aco drain against house, could I go within the recommended 150mm of original DPC, also taking into account that a new injected DPC would potentially be installed at a new higher location.
any guidance/advice on this would be massively appreciated. I appreciate how busy we all are and your time given to this is amazing.
thanks in advance.
thanks in advance.
