Drainage question
Discussion in 'Builders' Talk' started by Lewis Finnigan, Sep 24, 2021.
  1. Lewis Finnigan
    Lewis Finnigan New Member
    Good morning everyone , just a question about the house that keeps giving , I have attached a image from a downpipe coming off my original house which has a extension to the left as you can see there is no drain as such just a hole where the water pools up against the side of the house then drains away slowly is this correct or should there be something in place if so what can I do to solve this , thanks
  2. Severntrent
    Severntrent Screwfix Select
    Extend pipe run further away from house into purpose built soakaway or route to combined sewer
  3. GRH
    GRH Member
    And I would re-point those bricks too.
