Drainage
Discussion in 'Getting Started FAQ' started by scotia, Jul 12, 2018.
  1. scotia
    scotia New Member
    Have an internal drain running between the ceiling and 1st floor. Due to the shallow fall sometimes blockages occur.
    The idea is to put a 4gall tank at the head of the drain run with a 110mm pipe discharging directly into the drain. No problem drilling the tank to fit the pipe and making the connection to the drain, the problem is getting a diaphragm to work with the 110mm pipe. Any suggestions?
