Drayton TRV4
Discussion in 'Plumbers' Talk' started by bigjules, Jan 7, 2008.
  1. bigjules
    bigjules New Member
    Here's the situation....
    Radiator in new shower room is fitted with a Drayton TRV4 which doesn't appear to work - the rad is always boiling hot despite the setting of the TRV.
    The pin isn't stuck and its the same when substituting a TRV head (that works) from another room.
    The non-working head from the shower room works on other rads.
    I'm perplexed..........
  2. Walterfilter
    Walterfilter New Member
    what you clearly have is a trv head that works but a valve thats knackered..........
    change the complete trv......
  3. v12man
    v12man New Member
    Take the trv head off, push the pin down and see if the flow to the rad stops, if it does then valve is fine, if not, valve is dead as Leaky says!
