Drilling into a Concrete (council style) Slab - Cannot do it, help please.
Discussion in 'Builders' Talk' started by StevenUK, Jul 1, 2018.
  1. StevenUK
    StevenUK New Member
    Hi,
    I am attaching a pergola to a concrete base, onto the slabs, which are council style, 50mm or so thick.
    I have this as the drill:
    https://www.screwfix.com/p/dewalt-d...-cordless-combi-drill/899cf?_requestid=366354
    And this as the drill bit (14mm):
    https://www.screwfix.com/p/straight-shank-masonry-dril-bit-14-x-200mm/1550v?_requestid=366707
    And it is hardly making a dent in it, and if I try and force it, it will knacker the drill I feel.
    I did drill one hole yesterday, and it took around 20 minutes, and tried another one today, and it is hardly getting past 1cm deep.
    Can anybody please advise, as the missus is now getting impatient and wants this pergola put up, and I cannot even get into the concrete for the holes.
    Thank you in advance.
  2. jonathanc
    jonathanc Screwfix Select
    Sounds like an excuse to buy a new toy/ tool
    If you really want to drill into slabs then get yourself a mains SDS drill. Titan one is ok
    Else lift the slab and pour concrete: probably more stable anyway
    StevenUK likes this.
  3. PhilSo
    PhilSo Screwfix Select
    Start with a smaller drill bit
    PhilSo
    Heat and StevenUK like this.
  4. StevenUK
    StevenUK New Member
    I only just got the drill - cordless dealt one. Seems powerful enough, but just not drilling it.
  5. StevenUK
    StevenUK New Member
    Thanks I will try that, just seems like it is like drilling through steel.
  6. KIAB
    KIAB Super Member
  7. StevenUK
    StevenUK New Member
    Thanks everyone, I just made 4 holes starting with like an 8mm bit, and worked my way up to 14mm, and that seemed to do the trick, although discharged 2 x dewalt batteries doing it, but did it.
    One is a lean to pergola, so 'only' another 20 holes to go...
    I definitely appreciate the help!
  8. Astramax
    Astramax Super Member
    Do yourself a favour Hire an SDS drill.
    KIAB likes this.
  9. Sparkielev
    Sparkielev Screwfix Select
    The hammer action on your drill is far different to a SDS it sounds like it is screaming where it should sound like it hammering the drill bit in get a SDS drill
    Astramax and KIAB like this.
  10. WillyEckerslike
    If this is truly 'council style' there's not enough of you (at least one should be permanently on his/her phone), a nineteen year old supervisor with 'disco shoes' should be in attendance and most importantly, despite your concerns you're still doing it too quickly.
  11. PhilSo
  12. HarDeBloodyHarHar
    HarDeBloodyHarHar Active Member
    Then when you come to build, cut your posts with a breadknife. keep going, you can do it!
  13. PhilSo
    Not at all amusing. Even though you think it is.
    Arrogance
    PhilSo
  14. PhilSo
    Obviously not sober :cool:
  15. WillyEckerslike
    Having worked on both sides of the fence I speak from experience. And you're right. It's not amusing. It's outrageous. Couldn't wait to get out. Work ethic sucked out of you like a drip in reverse. In fairness it might not be as bad nowadays....
    Edit. It was meant to be funny so sorry if offence was taken.
  16. JustPhil
    JustPhil Active Member
    Whilst an sds is deinfitely the answer I’d have thought you should at least be able to get through a lot quicker than twenty minutes with a combi drill.
    I picked up on your comment in your OP “it will knacker the drill I feel” and I suspect you might be applying too little force. A hammer drill relies on hammering, and that requires force/weight behind the bit. Put your back into it, you have a good quality drill there that can take it.
    Masonry bits don’t cut by virtue of spinning - that causes heat in the bit and blunts them - instead it’s the hammer (like a masonry chisel) action combined with rotation which clears the debris.
    If you do get an sds on it you’ll be amazed at how easy it is though :)
    Astramax likes this.
  17. Heat
    Heat Screwfix Select
    Ordinary SDS masonry drills are not good at drilling very hard materials like high density concrete slabs. Those drills are designed to chisel into what is being drilled and that is obviously no use on slabs.
    What you need is to use sharp masonry drill bits starting with a small size and working up to your largest needed. A 5 or 6 mm bit is good as a starter.
    Even a good ordinary hammer drill will work well with a non SDS bit if it is a top quality drill bit used.
  18. rogerk101
    rogerk101 Screwfix Select
    Keep your drill bit cool by dipping it in a bucket of water.
    Masonry drill bits are made with hardened steel and one thing they do in the hardening process is shock cooling the metal to get it harder. Allowing it to cool down naturally undoes all the hard work the manufacturers did to get the metal hard.
    FWIW, I was so excited when I bought my first cordless combi-drill, but soon became disappointed by how poor they are at masonry drilling. I was so spoiled with my prior experiences with good corded drills that I now don't even bother trying drilling into bricks or concrete with my cordless drill. I still use my 30 year old Metabo or my 20 year old Makita corded drills.
  19. Heat
    I have a Hilti 22 volt combi drill and despite it being an average sized drill, it is easily capable of most masonry drilling for rawplugs etc.
    So it also depends on the quality of the cordless drill.
  20. Heat
    What combi drill did you buy?
    Got to pay decent money, but I have been surprised at how good the cordless are.
    Although for large diameter holes in concrete block walls the mains voltage drills are better unless you buy the best heavy type of combi.
    Ask some trades folk to let you borrow their combi to do a test drill hole.
