The Q-Max cutter works by you drilling a hole large enough for the bolt (it doesn't matter if theis hole is a bit ragged, as it will be in the waste). Then you place one half of the cutter over the hole on one side of the sheet, the other half on the other side, thread the bolt through and tighten with hex key until it cuts through the sheet. This will give a very clean cur.
BB
