Drills, which one?
BMC2000
Screwfix Select
Hi, need to get a decent cordless.
I will be using occasionally but need to prepare drill concrete with 5mm bits and then drive 6mm screws into it thereafter - that task will be quite common and the concrete will vary in strength so need something decent to cover me.
Ideally I will have a masonry bit in one evening cordless and a drive bar and torx head bit in the other to save changing bits etc
Would this be suitable
www.screwfix.com/p/erbauer-eri742kit-18v-2-0ah-li-ion-cordless-combi-drill-impact-driver-twin-pack/9478t
Or is there a better set? PS Don't want to go much past £150, happier with less than 150!
Thanks
Forget Erbauer, no spares available. Other threads on this, do a search, look for KIAB's posts suggesting Bosch models. I'm Makita myself but could be pricey.
https://www.screwfix.com/p/bosch-gsb-18-2-li-plus-18v-2-0ah-li-ion-cordless-combi-drill/5916t
https://www.orbitalfasteners.co.uk/...MIsOCY-Obw2QIVGWQZCh1hDgSyEAkYASABEgJLNPD_BwE
If I £150, then Bosch GSB 18V-EC brushless combi top of my list, search you might find cheaper, also topcash back & quidco, might save you a few more pennies.
https://www.priorityplumbing.co.uk/...tt-in-l-boxx-TPBOSHH0?gclid=EAIaIQobChMIsOCY-
Obw2QIVGWQZCh1hDgSyEAkYAiABEgIUyPD_BwE
I have both the drills linked to above can't fault either, but the the brushless combi has the edge for power.
Again you search you might find better offer, but a inclusion of 4Ah battery is perfect if you want to add other cordless tools to your collection like the Bosch GKS 18 V-LI
circular saw, which I have, & tend to use more than my heavier mains saw.
Both drills I linked to are well balanced, both are compact, & the led lights are actually useful, batteries last ages.
i use the BOSCH GSB 18-2-LI PLUS, love it much better than my other Dewalt that constantly drops the drill bit or driver bit out. Battery on Bosch also has a charge indicator on it
Used with Bosch multi construction bits, it can handle most masonry, might struggle with drilling Accrington bricks being so hard.
Link to those bits KIAB? Also, what do you recommend for connecting screwdriver bits, this sort of holder? www.screwfix.com/p/erbauer-magnetic-bit-holder-60mm/11144
https://www.screwfix.com/p/bosch-multipurpose-drill-bit-set-4pcs/95958
Might find cheaper if you search, also 7 piece set available at competitor
Some of the magnetic bit holders are not suitable for impact use, had one & it shattered.
I use,think it's a Wera Impaktor or their BiTorsion Rapidaptor bit holder, not cheap though.
Picked up the GSB 18 for 86 quid in B and Q
They are running their BOSCH stock out in favour of other brands, worth seeing if there's else
Good price, if GSB 18-2-Li Plus, you'll like it.
You will find yourself adding other bits to your kit now.:D
Added circular saw last year, use it more than my mains one now.
Bought the GAA 18 V-24 USB battery adapter last month, can now charge my phone & AA batteries.:)
Yes, KIAB same model. The guy was waxing on about how good a deal this was as he had one. I was thinking he may have been following this thread ! Cheers again
Back
Top
