Drip marks on newly painted door
Discussion in 'Painters' Talk' started by tomu, Dec 3, 2017.
Tags:
  1. tomu
    tomu New Member
    Hi
    Just primed and painted 2 doors. Looks good but a couple of small marks on each door, which I think are drip marks from the knotting solution I hastily applied prior to priming.
    Any advice on how I can fix these blemishes? Could I just sand these specific areas down with 220 sandpaper, prime and paint the small area? Would this blend in with the rest of the door?
    I’ve attached a photo that shows one of the blemishes.
    Thanks
    Tom
  2. Isitreally
    Isitreally Super Member
    You could probably rub it down and just repaint that area, due to the fact that the rest of the door doesn't look particular well painted anyway, so it wouldn't stand out to much.
  3. Rulland
    Rulland Screwfix Select
    They're not drip marks, just a poorly prepared door, see left and down.
  4. Astramax
    Astramax Super Member
    Well at least he tried so top marks but next time use a paintbrush. :D;)
  5. tomu
    tomu New Member
    Thanks for the replies. This is my first attempt at painting a door, give me a break:).
    Will I have to prime it again
    or just sand area down and touch up with paint?
  6. Rulland
    Astra is the man:)
  7. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Oooo, well!
  8. Astramax
    As Isitreally wrote, rub down all over and another finishing coat will do the trick!
