http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=101897&ts=05331&id=63756# Do this drive drain have a corner bit with it,for going round a corner? Cheers,jace
I have never seen a fitting to go round a corner, but assume that you use a 90 degree bend underground to join them and run the finished surface across the top. Charlie Farley will be along shortly with some abuse to cheer us up though and give us the 'Charlie answer'
