Dualux Ceramic Disc Cartridges--Replace or Clean
Discussion in 'Plumbers' Talk' started by einhorn, Apr 17, 2019.
  1. einhorn
    einhorn New Member
    Hi,
    We have 2 or 3 pairs of above bathroom taps and over the years have replaced cartridges with new ones when taps got bad drips. Now run out of cartridges and wondering if all the old ones I have kept can be cleaned in some way and re used as new ones pretty costly.
    Many thanks
    All best
    Frank
  2. andy48
    andy48 Active Member
    Probably not. Try cleaning and fitting a set and see what happens.
    You can also get new rubber washers for the bottom of the taps, the washers which put the ceramic discs under compression. I've never used them, but you could give them a try. See Ebay for suppliers.
