Dusk till Dawn sensor loadings?
Discussion in 'Electricians' Talk' started by Virtual Voodoo, Jan 21, 2008.
  1. Virtual Voodoo
    Virtual Voodoo New Member
    Hi Guys,
    Need to fit 2 x 400W Metal Halides on a pole for a Car lot.
    Will a standard Dusk till Dawn sensor run this without a contactor?
    Seem to remember that they'll swith 2000W OK?
  2. pro_engineer
    pro_engineer New Member
    Not sure if they have standard ratings but the most common one I see available is rated at 5Amps.
    Zodion also make an 8 Amp version.
    Google it dude
  3. pro_engineer
    BTW just for reference the correct terminology for this device is a photocell, but you probably already knew that.
  4. Dont risk it. It won't last without a contactor, whatever the ratings calculate to.
  5. pro_engineer
    Would tend to agree Slip, also the contactor can be located somewhere a little more accessible than the photocell which may well be at the top of a column.
    At least if the contactor fails you won't have to shimmy up the pole !
