E10 petrol
Discussion in 'Car and Van Talk' started by Adamfya, Nov 20, 2021.
  1. Adamfya
    Adamfya Active Member
    Anybody having any issues with the new fuel?
  2. quasar9
    quasar9 Screwfix Select
    No, but did not replace a worn petrol lawnmower because most small carbureted engines cannot handle e10 fuel unless used everyday. The mower got used once a fortnight in spring falling to 3 to 4 weeks in summer and no use for best of the remaining 7 months! Apparently, the ethnol is hygroscopic and absorbs moisture making starting tricky. Some agricultural machinery manufacturers are selling fuel preserver but cost of this plus e10 is more expensive than super unleaded.
  3. goldwise
    goldwise Active Member
    What fuel would you use for a lawnmower? Super unleaded?
  4. quasar9
    Yes unless you want to use fuel preserver with E10
  5. woodbutcherbower
    woodbutcherbower Well-Known Member
    I have a 1957 Morris Minor. I haven't dared put any E10 in it yet - I can't seem to find any definitive information regarding whether it's safe to do so. Any knowledge out there would be massively welcome.
  6. Astramax
    Astramax Super Member
    Same age as my sweet wife........needs trading in for a younger model! :oops:...;)
    woodbutcherbower likes this.
  7. woodbutcherbower
    I already have one mate. Difference is that I didn't find my girlfriend sat in the middle of a field covered in rust and cows**t :)
    Astramax likes this.
  8. Wayners
    Wayners Screwfix Select
    Brazil was running e10 in 1976..
    E27 today and they managed no problem. Makes me wonder and maybe the answers for people with older cars was to follow what they did. Although I don't know much about it but heard on radio.
  9. JOMEL
    JOMEL Active Member
    Hi Guys
    I have a 1995 2.2ltr Toyota Camry.
    I purchase it new so I had it 26 years.
    127K on the clock.
    Its called a Classic now I though it was just an old car.
    Toyotas info on it was NOT to use E10.
    I am using Super Unleaded E5
    My only gripe is its 10 pence a ltr more expensive in the UK,
    Cant win,
    Johnny M
  10. Johnik
    Johnik New Member
    as someone who now retired but who spent most of their life in the motor trade i have interest in this subject.
    as far as i can make out you will get less MPG, if you have a classic it will rot rubber fuel pipes and copper floats in carbs, it also contains water that is not good when the engine is left to sit around doing nothing in things like lawn mowers, as others have pointed out, using super should get round the problem, most classics should have the newer spec fuel pipe by now but for the sake of a couple of quid it will be worth changing it (not from the likes of E bay tho as there is some dodgy stuff being punted as the latest spec)o_O
    Wayners likes this.
  11. AnotherTopJob
    AnotherTopJob Screwfix Select
    Been using E10 in my 1995 Astra, no issues or drop in MPG noticed so far.
    Problems that might arise in older cars are fuel hose breakdown and possibly rust in metal fuel tanks. Anything with a carburettor is likely to be incompatible.
  12. quasar9
    While you may not notice a drop in MPG under general observations, there is a real drop as chemically ethanol has 38% less energy for a given volume than petrol. The fact E10 is 10% ethanol, means it has few percent less energy than super unleaded for a given volume. All other things being equal ( the power generated by the engine) , for a given vehicle, the MPG will drop by the same %. There is no getting away firm this , this is hard chemistry and physics. The carbon emission will be the same too. However, eathnol is made from renewable sources unlike fossil fuel, hence its introduction.
    On Brazil with E27, ultimately they will have to decide weather to use land for growing food or fuel ,
  13. AnotherTopJob
    A 3% overall drop in economy seems to be a common figure, so with a consumption of 40mpg it's only about 1.2mpg less, something that could easily be absorbed by a better driving style.
    On older cars, they're often listed as being incompatible simply because E10 wasn't around when they were built, and long-term testing isn't viable. If something can't be guaranteed, manufacturers will always advise against it to cover themselves.
    The best place to see of any common issues on older cars is owners forums, in some countries such as Brazil as mentioned, high ethanol mixes have been used for many years.
