Ear clips or jubilee best?
Discussion in 'Plumbers' Talk' started by Txm0984, May 23, 2020.
  1. Txm0984
    Txm0984 New Member
    Hi,
    need to connect some 10mm rubber hoses to an UFH manifold (90’s system).
    any thoughts on using quality jubilee clips or double ear clamps?
    which is strongest?
  2. The Teach
    The Teach Screwfix Select
    CMC-C clips dont look strong but they apply even pressure around the soft plastic pipe,its easy to damage the soft plastic pipe to manifold nipple connection with a jubliee clip.
    Can the existing ufh pipe be identified ? it could be kee triple,was around in the 90's . You have probably found this company already,they do a few fittings.
    As a guide https://shop.nu-heat.co.uk/collecti...c-size-95-manifold-stainless-steel-clips-each
    think they had a conversion connector for when fitting new manifolds.They have a decent tech dept and usually very helpful email them.
    TT
    WillyEckerslike likes this.
