Indeed - the purpose of earth bonding is to prevent all that metalwork in the bathroom, where it can easily be touched by wet hands, from becoming live. A good earth will cause a sufficiently large current to flow to operate the protective device on the circuit (fuse or MCB), thus preventing your bathroom fixtures and fittings from becoming live. Or at least from rising above 50V.
The point I was trying to make was that the death of the man holding a faulty appliance in one hand and a good earth in the other does not mean that earthing is a bad idea, it means that portable appliances in bathrooms are a bad idea. To suggest that pipework etc should not be earthed in case some idiot is holding a faulty appliance is utter madness.
And although RCD protection is "secondary" it is also very important. I realise that the example quoted probably dates back to pre-RCD days, but the same scenario could arise today, and if the (probably) upstairs sockets had been protected (a practice which some people here don't believe is necessary), then the man would probably not have died.
