Electric hob replacement
Discussion in 'Kitchen Fitters' Talk' started by John Cunningham, Sep 30, 2018.
  1. John Cunningham
    John Cunningham New Member
    Two out of four elements in my electric hob have gave up the ghost. I want to get a new hob. I lifted the old hob to see where the wire goes. It goes straight down into the ground, underneath the kitchen floor tiles, over to the other side of the kitchen where it is hardwired in.
    Can I just take the wires out of the back of the old hob and for them into a new one or do I need to tear my kitchen apart?
    Thanks in advance!
  2. CGN
    CGN Well-Known Member
    No. Its a yes, if you know what you're doing. If you don't, then its no.
  3. metrokitchens
    metrokitchens Well-Known Member
    I would get a sparks in on this one. No detail as to loadings or cable sizes.
    kitfit1 likes this.
  4. kitfit1
    kitfit1 Well-Known Member
    From your description OP, it looks like the wiring was done by a DIY'er in the first place. Absolutely get a sparks in to have a look and do the job for you.
