S
Steve A
Guest
Hi Folks,
We are re-fitting our kitchen, and have a couple of electrical questions that you can help with. The situation is as follow's.
So my idea is this to change the socket to a 20A connection unit connected to a 13A trailing socket again left on the floor and accessible via the plinth, the appliance can then be connected to this, no issue with warranty as the original cable and plug is intact and protected by the fuse in the plug and the FCU as before, again any comments.
Thanks
Steve
- There is a normal 45A cooker isolation switch above the worktops, and a CCU lower down that will be behind the units. The new oven is rated at 2.7KW, and the manufacture states it requires fusing. The cooker circuit is a separate circuit with a 30A fuse at the consumer unit. Therefore the oven can be connected to a 13A plug\socket.
- However here is the dilemma, there are no 13A sockets within reach, and I do not want to run the cable through the work top to any of the high mounted sockets, converting the CCU to a socket is also not feasible as this would not be accessible should the fuse blow in the oven plug as the units are secured to the wall, and we do not want to cut an access panel out the back of the units.
- So my solution is this, to use 2.5\4 mm cable from the CCU connected to a trailing socket that could be left on the floor, and accessible by removing the plinth on the units then plug a 13A fused plug from the oven to this, this would allow the oven to be protected by a 13 A fuse, this connection to be accessible and still be isolated by the current cooker switch and still on its own circuit, this would still be the only thing on this circuit. Any comments?
Thanks
Steve
