Apologies if this has already been covered elsewhere. I'm currently converting my garage into living space, part of which will incorporate an additional shower room. The current gas heating system for the rest of the house (13 radiators and two bathrooms) is just about at its limit. So, what I propose is to leave the existing system as is, but add a small independent hot water system for the new shower room that has its hot water from an electrical source rather than gas. I have identified several options to achieve this by installing a small electric combi boiler. However, the boilers are quite expensive (over a thousand pounds), and I wondered, can anyone recommend any other electric heater or similar that will function in line with a shower pump and will supply a basin as well?
