En-Suite light and extractor fan switch, help
Discussion in 'Electricians' Talk' started by kevin_g, Oct 2, 2020.
  1. kevin_g
    kevin_g New Member
    Hey guys,
    I would normally get an electrician in for any work, but seeing this is only two switches I think it may be embarassing to even ask one to come for a job like this and also, I'd kinda like to do it myself, but I am struggling with what is probably a simple job.
    I'm really not sure what switches to buy from screwfix.
    These are the ones I want to replace (pics attached) The reason is that when i switch the light switch on, the lights in the ensuite dont always come on, they may work fine for days then they suddenly stop working, then even with the light switch turned on, they will just turn themselves on about 30 seconds later.
  2. Bazza
    Bazza Screwfix Select
    The light switch is a regular light switch
    The fan switch is a double pole switch.
    You will find both types of switches in most ranges sold by SFX. Pick the style you like and find the switches in the catalogue or on line. Simples.
  3. kevin_g
    kevin_g New Member
  4. Sparkielev
    Sparkielev Screwfix Select
    What type of lights do you have in your bathroom?
  5. terrymac
    terrymac Screwfix Select
    The two black insulated conductors that are together in one terminal , need attention.
    Does your light run from a transformer ?
  6. Bazza
    kevin_g likes this.
  7. kevin_g
    kevin_g New Member
  8. terrymac
    That's ok for your lights, now find one for the fan !! Look for
    Double pole switch 20ax ,one gang. In the same finish and profile .
    kevin_g likes this.
  9. kevin_g
    kevin_g New Member
  10. terrymac
    That's the ticket !!
    kevin_g likes this.
  11. kevin_g
    kevin_g New Member
    Brilliant, thanks terry and bazza - appreciate the speedy responses too :)
  12. terrymac
    Those slim line switches sometimes don't sit too well on plastic drywall boxes. As the box itself protrudes from the wall a little. Doesn't bother some people but does to others.
  13. kevin_g
    kevin_g New Member
    dont say that to me
  14. terrymac
    Sorry ,but it's a fact. That type of switch is designed to sit flat and flush on the wall. It can't do that if a piece of white plastic is already there. Not just the brand your looking at , same applies across the board.
  15. Sparkielev
    Walls need to be like glass I hate when a customer asks me to fit them
  16. terrymac
    I hate it when the shallow galvy box which was fine with a plastic switch ,is now not deep enough to accommodate the
    " flat plate "variety. Advising home owner that a deeper one has to be fitted ,and that will inevitably involve damage to plaster work doesn't usually go down too well !!
    Sparkielev likes this.
  17. Sparkielev
    Yeah a nice shiny flat plate against a wall that's crumbled to bits
    terrymac likes this.
