Evenin' All Need to tank the bathroom ready for a shower. Current funds don't permit purchasing a cubicle yet, but I want to tank the corner ready for a 1000mm unit. My questions are: 1) Mid-range cubicles: what's your choice - considering Aqualux, Novellini - any others you would recommend? Also advice on shower tray brands - I need at least 100mm height - and probably a bit more to fit the waste in (above the floor). 2) What is normal procedure - tank to 1000mm from corners and then tile just beyond this? I am assuming that the frame MUST go on top of the tiles. Most panels seem to have a degree of adjustability from 960ish to 980ish. Thanks in advance for your posts WM
Easy, dry line your walls so flat and level ready for tiling, install an easy plumb shower tray securing it with silicone, tile, install enclosure job done
