I've just purchased multiple Enlite E5 downlights that i'm daisy chaining. Each downlight has 2 live and 2 neutral connections. 1 live and 1 neutral for both the incoming and outgoing wire. However there is only one connection for the earth. I presume I connect both the incoming and outgoing earth wire to the same terminal? Many thanks, J
Yes. Loop incoming and outgoing earths to same earth terminal provided in lamp. This will provide earth continuity. Remember to test before energising the work you have carried out. Good luck with your project.
