Hi All, long time reader, first time poster. The question I have is, do I need this work passing off / getting somebody to do it? regarding an ensuite refurb... I WILL NOT be altering the lighting circuit, but I WILL be replacing the downlights (IP65 fire rated). I will be removing the in-ceiling fan and replacing with an inline fan in the attic (isolator will be alongside the fan for use when fan needs maintenance) I will be fitting electric under floor heating (in a screed, under tiles) I would like to put a thermostat in the room for the UFH, 90cm outside of any zone 2 areas (trip will be outside the ensuite). If this last one is an issue, then I can always mount it outside the ensuite, but would have preferred it inside because of humidity and temperature being used in an automation system. PS location is England
Hopefully an electrician will confirm but as you are altering/adding circuits in a special location then I would think it's notifiable.
