Epoxy Grout
Discussion in 'Builders' Talk' started by Ian Scott, Jul 17, 2005.
  1. Ian Scott
    Ian Scott New Member
    Can anyone give me some advise regarding eopxy grout?
    I have a wall which epoxy grout was used, the grout has dried but there is excess grout on many tiles and there is a haze over all of the tiles. Is the wall ruined, or is there anything I can do to make the tiles look good again?
    Any suggestions would be much appreciated.
  2. bathstyle
    bathstyle Active Member
  3. Sorry, it's screwed.
    Unless the manufacturer can give you any advice on solvents.
    Usually the solvent would need to be so severe that it would strip or bloom the glaze on the ceramics.
  4. bathstyle
    I take it cement residue remover would be no good then?
  5. no good Bstyle,
    Epoxy is used for two reasons..
    Resistance to chemicals and hygene.
    There would certainly be chemicals that would disolve the resin, but they would need to be so harsh they would likely dissolve the ceramic surface before the epoxy itself.
  6. Goddo
    Goddo New Member
