Epoxy resin floor calculation. How much??
Does anyone know how to calculate how much epoxy resin is required for a 4 metre by 5 metre room at 1.7cm thick
I was/am hoping to get an answer from Epodex but their calc say i need 220kg of resin!! That's mega-money!
I cannot get straight answer anywhere
4m x 5m x 17mm = 0.34 cu. m
1 cu.m =1000 litres.
EM weighs 1.1kg/litre
You need 370kg
Epodex based their figure on 10mm thick & 1.1kg/litre
Check the thickness required; it is probably substantially less.
You need 370kg
Wow!!!! that's not going to be cheap... It sounds horrendously expensive. Many thanks for this.
Just spoke to a company rep and reckon around £550 for a 5 by 4 kitchen.
I think I'll stick to lino since it's for a rented house!
Massive thank you for your help dude.
Back
Top
