Expanded foam copper pipes
Discussion in 'Plumbers' Talk' started by Jay459, Jan 11, 2018.
  1. Jay459
    Jay459 Member
    I have a 2 storey garage which is partitioned downstairs, on the roller door small side all copper pipes go up one side of the wall and waste pipe for toilet upstairs...
    Its newly built but left roller door open the other night and my wife who works from garage thinks there is a mouse inside.
    This is quite possible as there is loads of cracks and gaps around copper pipes and waste pipe at my side of the garage...
    Need to get this small area of ceiling sealed up. Is it ok to use expanding foam around copper pipes or is there a better solution?
  2. Dave does Gas
    Dave does Gas Well-Known Member
    Expanding foam is ok but chewble by rodents Mastic is a good alternative or decorators cork.
  3. sospan
    sospan Well-Known Member
  4. KIAB
    KIAB Well-Known Member
    Mice hate copper.
    Also want to put down some rodent bait in safe places.
  5. The Teach
    The Teach Well-Known Member
    you really need some evidence to confirm its a mouse,it could be a rat o_O
    With evidence an accurate remedy is possible.
  6. retiredsparks
    If it's a rat...what is the solution.
    If it's a mouse...what is the solution.
    What is the "accurate" remedy for each.
    RS
  7. Pollowick
    Pollowick Well-Known Member
    Best way to deal with a rat is a "high speed injection of lead", whereas a sprung trap is best for a mouse.
    retiredsparks likes this.
  8. sospan
    Same solution for mice and rats - just have to hunt out the smaller holes for mice
  9. sospan
    Had to fix a ceiling where somebody thought it would be a good to get rid of the rat above the plasterboard by stabbing it with a garden fork ! After I had finished the electrician had to come in and replace the T&E where the plonker had shorted the electric - luckily for him it was a wooden handled fork
  10. The Teach
    Different poisons are available for different rodents.(via the trade).
    As the Op 'thinks' its a mouse,some more evidence is required to find a remedy to the concern,expanding foam has its limitations.
  11. sospan
    Nobody is recommending expanding foam. Even if there is no mouse it is good practice to block any holes to prevent access
  12. The Teach
    Best to call in a professional rodent control company,
  13. Jay459
    Jay459 Member
    I live in the country. Field mice are common. Rats are dirty, very much doubt there is a rat here.
    The mouse seems to be stuck under floorboards, so does that mean i need to get trap through gaps and into area between the joists. As if i seal the access point up then mouse will be stuck and can't kill it...
  14. KIAB
    Unlikely it's stuck, they can get through pretty small holes.
    CGN likes this.
  15. retiredsparks
    I suggest this;
    RS:cool:
    KIAB likes this.
  16. Dave does Gas
    Just like to point out that the chemicals in cement eat into copper. Otherwise great idea ;)
