DIY_Has123
Active Member
I'm fitting herringbone flooring, real wood with 3mm wear layer and overall 10m thick.
I've left the recommended 10mm expansion gap all around the room +/- 2 to 3 mm.
Around the door frame here, can I tightly butt the flooring up against the frame where it won't be covered by the architrave or is this not recommended?
A gap with sealant won't look as good.
Other option is to fit these plinth blocks and trim the architrave to fit on top and skirting on side. This will allow full expansion gap around the frame and cover it up. Though I'd have to go through the trouble of making one, I'm sure I have plenty of MDF or wood offcuts for this.
Please see images.
Please see images.
