expansion gaps on windows
Discussion in 'Builders' Talk' started by clueless jon, Sep 14, 2009.
  1. clueless jon
    clueless jon New Member
    HI, can anyone tell me, when building in a window, is it necessary to leave a 5mm expansion gap around it or can i just build right up tight to it? it's a wooden window going into stone . thanks in advance
    Jon
  2. Mr GrimNasty
    Mr GrimNasty Active Member
    Wouldn't bother, UPVC expands about 10 times as much as wood and <u>is</u> quite significant, but wood is negligible.
  3. flippin heck
    flippin heck New Member
    Hi,
    A small gap of a few millimetres all round will allow a better external seal to be achieved between the frame and stonework. What you should be aware of is that a vertical DPC should be present between the frame and stonework, as moisture could travel from the stonework (or mortar) to the timber frame where they are in contact.
    Hope this helps
    Dave
  4. clueless jon
    thanks. very good. will do
    jon
