External downlights
Discussion in 'Electricians' Talk' started by bigjules, May 20, 2009.
  1. bigjules
    bigjules New Member
    She who must be obeyed has come up with the idea of having downlights in the soffits of our single storey extension.
    Any recommendations for a suitable fitting?? Soffits are uPVC so generated heat could be a consideration......
  2. Bathroom IP65 ones...
    Reggie
  3. betty swollocks
    betty swollocks New Member
    i'd agree with reggie
    i've just done this for a customer and installed 'cheap' megamans at £3.50 each, instant light not really an issue and added bonus of cool lamp and fitting not discolouring upvc soffit.
  4. mrmanager
    mrmanager New Member
    the absolute easiest method for doing this is called "divorce"
    saves you even having to get out of bed then
  5. mbat666
    mbat666 New Member
    Have some of these at mine and have put led Gu10 bulbs in. Although they cost about £6 easch they only consume 1 watt so don't run away if left on all night. Obviously the light ouput is limited but they look good
  6. mbat666
    mbat666 New Member
    i mean run away with electricity (not just grow legs and run away)
  7. bluevelvet
    bluevelvet New Member
    agree with betty and reggie but!
    put 8 GU10 IP65 3watt leds in a garage sofit two years ago
    but find now they are just starting to show signs of rust
  8. Guest
    To avoid the rust you can spray paint the fittings with stove paint this then prevents corrosion. I use forest heat resistant spray.
  9. Lokkars Daisy
    Lokkars Daisy New Member
  10. bluevelvet
    lesson learned there lockers
    did suggest Stainless ,but the customer bought chrome plated instead. Still live and learn
  11. lightning bolt
    lightning bolt New Member
    you will learn till the day you die
  12. bluevelvet
    lighting - if thats right , i "hope" that iv`e got a lot more leaning to come yet
    bv
  13. lightning bolt
    its very true keep learning:)
