External Paint, Windows
Discussion in 'Painters' Talk' started by CraigMcK, Apr 15, 2019.
  1. CraigMcK
    CraigMcK Well-Known Member
    Hi
    Just looking for a bit of input. It's come to that time when my external wood needs doing. Historically it has been coated with Sadolin woodstain, but I'm thinking about changing to something like Dulux weathershield. The wood is getting on and I will need to change a couple of bits, hence the preference for something opaque to save the new wood showing through the Sadolin
    Any pointers, options etc greatly appreciated.
  2. LEH
    LEH Active Member
    Bedec Barn paint, Zinsser Allcoat Exterior, Sadolin Superdec :)
  3. sospan
    sospan Well-Known Member
    I would have a look at the Dulux trade Weathershield system. It is a 3 part system which includes a primer and wood treatment, then an undercoat followed by a top coat of gloss.
  4. Astramax
    Astramax Well-Known Member
    Reading your post and what you require from the paint look no further than DuluxTrade Weathershield Ultimate Opaque, a superb product available in a good colour choice, it would have no problem in covering and adhering to the previous stain finish after initial preparation and provide lasting protection for up to 10 years.;)
  5. sospan
    Opaque still requires priming tho ....
  6. Astramax
    Only on new or bare wood.
  7. sospan
    When I was looking for paint for my windows, I had a chat with the guys in the colour centre they didn't recommend applying directly without an undercoat / primer
  8. Astramax
    Perhaps they hadn't read the Dulux Data Sheets, or the Data Sheets are wrong.
  9. gac1967
    gac1967 Member
    I have used Dulux Trade Weathershield Ultimate Opaque on numerous exteriors and it is very good , it is solvent based and water repellent, and can last up to 10 years if done correctly, off the top of my head I think its around £50.00 for 2.5 litres.
  10. Astramax
    Did you use a primer as the data sheets indicate that for use on new timber only.
  11. gac1967
    gac1967 Member
    Windows had already been treated over the years and no bare timber so just prepared them and painted them an never had any problems. Obviously any new or bare timber would need the correct primer but I have been lucky. ;)
  12. Astramax
    Ok, thanks, was beginning to doubt myself for a moment after sospans reply!
  13. gac1967
    gac1967 Member
    No you are totally correct Astramax
    Astramax likes this.
  14. sospan
    The data sheet does say prime first on bare woo. Whether the interpretation is that weathered stained timber is classed as "bare" or they have had issues previously, I don't know.
    However, giving something a coat of primer isn't much of hardship and something I would do anyway when radically changing products
  15. gac1967
    gac1967 Member
    Bare or new timber coat with primer, but if you want to put on a coat of primer to be on the safe side go for it.
    33 Years as a Painter and Decorator and I am still learning :confused:
  16. Astramax
    I would probably use bullseye if priming to provide a good key for subsequent coats.
    gac1967 likes this.
  17. CraigMcK
    Thanks for that, I'll have a look at some of those
