Hi, I’ve bought an Xpelair extractor fan and it has 3 connections (L, N, T). My lighting cable just has live neutral and earth. Any suggestions as to how to wire up would be very welcomed! thanks.
3 core and earth) Connect the L and T connections together, it will mean that the timer function won't work but the fan will work and it will save you having to run another cable. (3 core and earth) I'm assuming you have a switch for the fan?
That is exactly how he behaves on DIYNOT, under a different handle. Little constructive Information, Often misleading. Orherwise just sniping and put downs.
Thanks for your response. No I don’t have a switch - won’t it just work with the lights? I’m afraid that the manual is silent on all points!
At the ceiling light fitting , what conductors are present , do you only have the switched live ,neutral and earth ? No permanent live ?
At the wall switch you might find you have live and live return which you might of mistaken for the neutral a photo would help if you could post one of the switch wiring..
If you want to have the extractor run on using its timer ,you have to run a permanent live ,switched live ,neutral and earth to it. You may have all present at the switch location ,if so ,you will need to run a cable from there to the extractor.
Ah! Yes I think that must be the case but the main circuit isn’t accessible without taking up the floor above so I think I’m stuck with having to connect into the L/N/E
Hmm. That’s what most fans do! With a timer fan, the idea is that the fan continues to run after the light is switched off.
I don't know how far you're into the job, but I've just fitted one in my kitchen and it was going to be a big job to run any lighting cables anywhere near but it was very close to the socket radial that was in surface mounted trunking. So I bought a humidistat equipped extractor and used a switched FCU fused down to 5a spurred from the socket circuit. Leave it switched on all the time and it comes on every time I boil the kettle or run the hot tap, seems dead handy so far!
Good thinking - but my fan is in a toilet so that might not work. In the end I decided to take up the floor above aNd run the wires from the junction box. Rather more work than I’d bargained for but it seems to be working now so I’m rather relieved!
