Extractor fans
Discussion in 'Electricians' Talk' started by aidanmcg33, Dec 4, 2017.
  1. aidanmcg33
    aidanmcg33 New Member
    Do bathroom extractor fans need to have isolation switches for building control?
  2. JP.
    JP. Screwfix Select
    Aye they do tbqh
  3. plastic bertrand
    plastic bertrand Active Member
    Yup, think it's building regs, rather than lecky regs?
  4. Bazza
    Bazza Well-Known Member
    Building regs Part F (ventilation) will specify the extract rate and any over-run requirements.
    Building regs Part P will determine the standard that the electrics should be installed to. That says BS7671 is the recomended way to go.
    Also following the manufacturers instructions will be included.
  5. Peterdevon
    Peterdevon Member
    quite a few require fuse protection at 3A as well
  6. Coloumb
    Coloumb Well-Known Member
    ...so it's best to run your whole bathroom lighting/fan ctt off it's own fcu with a 3a fuse in it. I mean so long as your bathroom isn't wanting the Blackpool illuminations in it.
  7. Dr Bodgit
    Dr Bodgit Well-Known Member
    Now why didn't I think of that...bought an FCU and 3 pole isolator for the fan, but could just put the whole lot on the FCU :) 3 pole isolator ain't cheap either...can return it to our hosts.
    tore81 likes this.
