Fake turf - Artificial Grass advice needed. See pics
Discussion in 'Landscaping and Outdoors' started by bond007, May 9, 2016.
  1. bond007
    bond007 Well-Known Member
    Guys
    I'm after a bit of advice and help please. I have attached pictures of the garden section which i want to leval with the existing flagging. The area in question is currently where the grass is. (HEXAGON part)
    I want to possibly remove the tree and square box from the middle - depending on cost.
    Or just work around it and lay the fake turf. The section is approx 17ft * 16ft and needs 0.6ft raising to it will be leval with the paving and in line with the sleepers. On the pictures i have highlighed it in the red.
    My question is what would be the cheapest way in going about it? Will i have to concrete that section or is there a different way?
    How much will it cost approx ?
    I only want to turf the HEXAGON part leval to the sleepers.
    Thanks in advance
  2. bond007
    Or if anyone has a step by step tutorial for DIY.
    Will need to find out if i need to put core on it to riase the ground leval
  3. Phil the Paver
    The fact you are low is in your favour.
    Removing the box will make your life so much easier.
    (1) remove box.
    (2) cut existing grass.
    (3) fit treated timber to the existing sleepers to bring level up to the paving
    (4) lay a membrane over the area.
    (5) lay 20mm stone over the area, round stones not crushed (Sharp edges may cut membrane) compact with a plate vibrator, to within 30mm of finished level.
    (6) lay membrane.
    (7) lay sharp sand over the area compating to within 5mm of finished level, you will need a straight edge to level the sand.
    (8) lay turf.
    You may need a treated batten around the inside edge of area to nail the turf down to, this stops it lifting.
    If it was mine I would go to the existing sleeper level with a batten fitted to the inside edge of those, this will leave you a small step down from the paving, but will be a lot easier for you to do.
  4. bond007
    Step 3 - u mean I should deck the entire hexagon area?
    Can I not fill the section area with pebbles ans flatten it Down?
    What would be the most cheapest option to choose?
  5. bond007
    Guys update on my Garden project
    I have removed the box and the tree from middle of hexagon part of the grass.
    The area in question to cover is about 28sqm. I need to raise it by approx 125mm, how many tonnes hardcore would i need to cover that area?
    Then put membrane on top of that and raise is another 25mm with sharp sand - how many tonnes will i need of that?
    Also am i right in saying i need build a inside hexagon sub frame so the turf can be nailed on to it?
    Thanks
  6. CraigMcK
    CraigMcK Screwfix Select
    Is this the recommended way of prep'ing for fake grass? I would think the sand would bed into the hard core even with a membrane and result in a lumpy lawn, but to your question.
    If you look at a builders bag being a cubic metre, you want 125mm depth from 1000mm high, so ~8 x 1m2 that is about 3.5 bags un-compacted. I would think you would be about 5 bags of hardcore. Sand is the same principle, you would get about 40m2 from one bag, so that would give you some spare. How are you planning to compact both down
    Can you get grass wide enough so it does not have a join in it? I believe you need to stake it down at quite small intervals, but never done it so no idea how important that is
  7. bond007
    Or my other option is to put the following in woogships and put the following for kids
    http://www.smythstoys.com/uk/en-gb/...re/?siteID=hL3Qp0zRBOc-Acc8DOkErZd1hNPSrgDw0A
    Would only raise is by about 35mm cos i'm not bothered after to be level with the flagging. Could be a cheaper option.
    How many bags of woodships would i need?..i would put membrane on top of the grass and then chips on top of it?
    how do i go about bolting the swing frame to the ground?
  8. bond007
    regarding laying the membrane , which GSM one will i go for?
    Only putting woodships on top so still need a heavy duty one?
  9. KIAB
    KIAB Super Member
    Use a landscaping fabric, it's made for the job.
    [​IMG]
  10. KIAB
    KIAB Super Member
  11. bond007
    Whats difference between landscaping fabric and membrane?
  12. chippie244
    chippie244 Super Member
    Membrane is basically a big plastic sheet, landscaping fabric is a woven sheet so it allows drainage but should suppress weed growth.
  13. chippie244
    Phil may or may not be using the same terms.:)
  14. Mike The Spanner
    Mike The Spanner New Member
  15. bond007
    Guys, the same area above in the post - how much would it cost approx to get it paved with big square slabs?
    So its in line with existing paving which is on the opposite side.
  16. KIAB
    KIAB Super Member
  17. bond007
  18. KIAB
    KIAB Super Member
    Use MOT 1 to raise the level,well compacted, with the weight of the slabs,may be possible to get away with bedding them on mortar,just a 30mm layer of sharp sand to lay them on, depends on the MOT 1.
  19. bond007
    So i would need to remove all existing grass etc first then lay a membrane on it?
    Then compact it with MOT 1 to raise the leval?
    Then Sharp sand?
    Then mortar on top to lay the slabs?
    Anyone care to do me a step by step guide please....
    Thanks
  20. bond007
    How would I got about if I wanted to just concrete this area in question?
    CAn I hire a concrete mixer and do the job.
    I Just want it flat up until the sleepers so its leval with the paving side of the garden.
    Thanks
