'Fast' but not 'powerful' PC.
Discussion in 'Just Talk' started by Allsorts, Sep 28, 2018.
  1. KIAB
    KIAB Super Member
    Agree 100%
    [​IMG][​IMG]
    As I said on page 1, [​IMG]could always go for a Ryzen 2400G for more poke if needed.
    Allsorts and ramseyman like this.
  2. ramseyman
    ramseyman Screwfix Select
    Trouble is he's ruled out building one himself which is a shame.
  3. CraigMcK
    CraigMcK Screwfix Select
    Has this not gone a bit far for email, surfing and online bridge!
    Unless I've got it wrong online bridge is not exactly a high processor/graphics intensive.
    None of this needs anything like the spec suggested. If you really think a Pi won't be capable for these very limited needs, you would be far better using Chrome OS on a chromebox if you want instant on and have the benefits of auto updating etc.
  4. Allsorts
    Allsorts Super Member
    Ah, I see what you mean - only a DVI is listed in the spec.
    I'm pretty sure it also has DisplayPort too, as I've seen it on that exact same machine on other sites. But I will check should I decide on it.
    Cheers Mr Ha.
  5. Allsorts
    Whereas there is no way on this planet you will ever get VDi.
  6. WillyEckerslike
    Don't you get that from Horlicks before you go to bed?
  7. Allsorts
    Is superglue needed for assembly?
    Thanks KitFit, I do see that that's a much better option. I would usually be happy to put this together - I have done most parts in a PC at one time or another - but this is different... If anything were to happen, then Nan would immediately have her suspicions; "Are you sure that part was meant to go there?"
    Overclockers don't have an assembly option?
    There's also the issue that it won't have 'Dell' or 'HP' or something she recognises on the case :rolleyes:
    You see what I'm up against :oops:
  8. Allsorts
    I reckon Horlicks would give you the DTs :)
  9. Allsorts
    Yup, waaaay over the top.
    This is going to sound nuts, but if I were to buy something that would just 'do the job', it would only cost a £ouple of hundred. And she wouldn't be happy...:oops:
    So might as well future-proof it as much as possible since the expected budget will be around £500-odd.
  10. WillyEckerslike
    You've read Horlicks as one word DA. An all too easy mistake......
    kitfit1 likes this.
  11. Allsorts
  12. kitfit1
    kitfit1 Screwfix Select
    Mmmm, so it's for your Nan and not your Mother in law DA ?
    Just explain to Nan/mother in law that Dell or HP are overpriced tat using old tech that will run as slow as a very slow thing running as slow as possible :D
    And nope..............no superglue would be harmed during assembly. The ownership of a pozidrive screwdriver would be handy though.
  13. Allsorts
    Mum-in-law IS 'Nan'...
    I need a simple solution to this. One that if it goes pear-shaped, it goes straight back - not me bringing oot ma screwdriver again...
    I DO understand what you are saying, how to get the best whatsit for your spondoolacs, but this has to be a simple solution for all concerned.
    At the moment it's the Fujitsu Esprimo Q556 or Ramsey's Dell Vostro 3470.
    Anything better 'off the shelf'?
    Ta. :)
  14. kitfit1
    Then go for the Fujitsu, it does have display port out, so you only need to get a display port to HDMI lead for it.
    I wouldn't know, i've never bought a pre-built pc in my life, never come across one that would be as good as or as cheap as one i'd built myself.
    Allsorts likes this.
  15. Allsorts
    Ok, cheers, KitFit.
    I would def go your way if this was for myself (actually, I usually just buy 2nd-hand...), but this one needs to be painless. :)
  16. KIAB
    KIAB Super Member
    Go to local supermarket, get Golden Delicious,Bramley,etc sticker & stick it on case, she will instantly reconise the brand as a Apple...:D
    Problem solved!:)
  17. Need a bigger hammer
    Need a bigger hammer Active Member
    Now that is funny...
  18. retiredsparks
    retiredsparks Super Member
    If I buy one of the excellent specced machines....will I be able to upgade from windows 3.1 ?
    Rs
    kitfit1 likes this.
  19. kitfit1
    Not unless you also change ya keyboard, mouse and ya little green screen as well RS. Of course, moving 28 years of saved Pron might be slightly more tricky :D
  20. Allsorts
    By your standards, bludy hilarious.
    KIAB likes this.
